scanmaster numbers Help
BurNrubR
Could someone help me out with the numbers? Tell me what you think please.
Air Flow 09
L8 60
Battery 13.0
Integrator 128
Block Learn 131
MPH 0
Coolant temp 145
Air temp 73
rpm 850
TPS .44
Idle air control 115
Code 44 but I just installed a new O2 sensor.
It looks to me as though the car isn't fully warmed up yet with 145* coolant temps. What degree thermostat are you using? 160? 185?
Idle Air Control (IAC) numbers are pretty high, however they might come down a little bit once the car comes up to operating temp and the car "settles" down.
AF number is just a tad high but not too bad. Again, if you are taking these readings while the car is warming up, the idle will tend to be a little bit higher.
As far as the Code 44 goes: What brand o2 sensor? What are your cross counts ("CC" on scanmaster) doing? Sure you plugged the sensor in?
Good news is that your INT and BLM numbers are right on the money. :)
Brand new denso and yes I was very careful not to bump it. I will have to look at cross counts again. 160 thermostat but your right the car was not running very long maybe 4-5 min.
O2 is reporting lean condition.
Typical causes for this code include:
1) O2 sensor defective or lead shorted
2) Lean injectors (dirty or blocked)
3) Water in fuel
4) Exhaust leaks upstream of O2 sensor
5) Fuel pressure or volume too low
6) MAF sensor reading lower airflow than is actually present
7) Vacuum leaks
8) Incorrect or poorly calibrated PROM
RL
Car has been sitting for six years so injectors could be dirty LOL, I also have some bad vac hoses.
