I took my Buick out on the street after installing my new 2.1 Scanmaster.I had consistent 761 O2 Volts and 9.8 Retard.The O2 Volts and Retard stayed the same to about 40 to 70 MPH then i stepped off the gas.I was running 94 octane on a 93 Jay Carter Chip.Could the Retard be wrong because it seemed to run fine or could 9.8 be a misreading???.i know on pump gas it is not good to go over 3 degree's of knock.I also want to get the O2 volts to a safer 800 O2 Volts so its not running to lean on pump gas.Im running about 17lbs boost on my TE-44 Turbo. Any advice on the Retard of 9.8 would be appreciated
