Safe boost on these mods.
robertf
So currently I'm running stock bottom/stock cam with Champion irons and port matched Champion intake/70mm TB/TH/60lb flow matched injectors/stretched IC/TR6 ignition/Razor progressive Alky/TH DP and ATR 2.5 exhaust.
So anyway, Eric offers an Alky chip for 23/25 PSI to go with the 60lb injectors I got from him. I'm currently at 18 PSI {non alky 5.7 chip} Car runs fine but wondered what difference it would feel with Erics chip 23/25 psi, alky turned up. Note: I recently refresh headgaskets with OEM. How safe is this? Thanks
I have been running 23-25psi boost with almost the identical setup, stock bottom end, with Eric's chip for years with no issues. Just make sure your tune is good. Car runs 10.90's@125+
