I did a search for tip in problems and found nothing so I'm asking you guys for possible causes and solutions.
After changing turbo, inj(60's) MAF, GENII, Extender G, I've got a car that runs OK cold, driving easy, and starts running poorly after it warms up. Cruising at 45-50 the BL's start dropping from 128-130 to 110-112 and the car stumbles when you add throttle after coasting. Its really bad when starting out from a stop even though it seems to idle OK while stopped. Have not gone into boost with it running so poorly and its difficult to test while staying close to home with busy traffic most of the time. Any ideas on what to check? I don't know what to check, twist, adjust or just plain cuss at! Thanks for any help you might throw my way.
MLH
MLH
