i have put new cosmetic head gasket and had the turbo redone from 60m to 70 mm but still have the same injectors fuel pressure is set at 43 with out vacuum when i kick it down froma dead stop it run real good but then falls on it face i also have methanol injection it set at 61/2 to 7 could to much meth make it fall on it face cause if it ran out of fuel i should back fire shouldn't it i replaced the coil pack but not the msd plug wire
