Running like S@$%t
CHARGED
Happened about 2 months ago, TType ran good all day then I went to get on the highway, hit the gas and the car just fell on its face, no power- no boost- nothing.
Limped home and changed the reman. MAF with the known good one off my GN, No change.
I have changed coilpack, O2, plugs, chip. The plugs were sooted up when I took them out and the car seems to be running very rich(by smell) FP is at 42 and everything on Turbolink looks normal and no codes?
Any ideas are welcome.
My car just did the same thing. I was going to start looking at everything you did, when I noticed that I had blew an intercooler hose. Make sure you don't have a leak somewhere.
You have probably checked this, but did the wastegate rod fall off the puck?
0 psi ............just a thought.
Looks like it was the module:rolleyes: I guess I should have looked to replaced that first since the sticker on it is from 86'
thanks for the help, its back on the road after being down for a couple of months :D
