Hey I'm a new member and owner a light blue stock 1987 turbo buick.Got it with 39k miles now have 60K.Was passing a car on the freeway felt the car hesitate a little. Got off the freeway and driving rough since, changed plugs, wires,coil(checked good on meter),MAF,O2.150 compression,turbo spins free cat not plugged ,hardly any back pressure on tail pipes,28 psi fuel pressure at idle 40 quick press of pedal.rough idle in park but a little bit pass idle engine smooths out.Friend with limited brought OTC said blms jumped to max quick other than that normal.Does not run better with cat off ,MAF,or with chip out.Please help this was my biggest fear owning one.Used to working on BB chevelles.
