I just got mine. I'll post the instructions tonight. The 90 deg end connects to the waste gate actuator and the straight end connects to the turbo compressor. (edited for correct information)
On your set up with a non- adjustable WG just leave it connected, install the RJC BC and screw it apart so there are a lot of threads showing (low boost) to start with and screw the BC together (less threads showing to increase the boost) until you get the boost you want.
Most guys, myself included, have either installed an adjustable WG or modded their stock one to make it adjustable for higher boost.
In this case it is recommended in the instructions to return the WG to the factory setting (factory boost setting, where you pull the WG actuator rod out approx. 1/8 inch to connect to the WG puck) and adjust the boost with the RJC.
I have read a lot of posts as well and this is my take on things. It seems that some guys can't get the boost high enough so they adjust the adjustable WG as well as the RJC.
I hope this helps.
