R regal-nut Member Joined Jan 14, 2008 May 6, 2010 #1 Ok the trans is a 200-4r (1985) the reverse works when it wants to. All the drive gears work fine. I was thinking of having the trans reverse flushed. Any insight would be helpfull. this 85 regal only has 68,400 orgial miles on it.
M mikestertwo Well-Known Member Joined Sep 13, 2006 May 7, 2010 #2 Does it do it when the engine is cold, warm, or doesn't make a difference? How's the fluid level? Shift linkage ok?
R regal-nut Member Joined Jan 14, 2008 May 8, 2010 #3 mikestertwo said: Does it do it when the engine is cold, warm, or doesn't make a difference? How's the fluid level? Shift linkage ok? Click to expand... shift links are good and no it does not matter hot or cold. Fluid is good. not burnt at all.
