Blacktop87
- May 2, 2008
Well I had trouble getting the car to Idle just right. So I searched day and night for the last couple of days and most of my time messing with the IAC screw and TPS.
So I decided to rest the IAC first, was reading the instructions like 20 times ( no lie) and when I saw the IAC numbers go down...the rpms would go up to around 1500 before I got tired of the noice, so I turned the car off. Put the ignition on (engine still off) and reset the TPS sensor back down to .42. Every time I would change one ...it would change the other. I did like 5 times to keep the bringing the IAC number down, and then reseting the TPS after every change of the IAC screw. The more I was bringing down the IAC, the TPS number would change (most of the time it went up).
So I had to keep going back and forth to change the number to where it would be nice and have no problem starting up with 1 turn of the key...not like 4 or 5 times when I first got it. Here are the number before and after.
837
AF 08
L8 56
Bat 14.1
Int 128
BL 128
MPH 00
CLT 165
ATS 71 ( I still need to replace this sensor)
r 850
TPS .48
IAC 82 ( yes..it was really that high.)
cc 247
MAL 23
After reseting everything:
863
AF 07
L8 50
Bat 14.0
Int 128
BL 115
MPH 00
Clt 170
Ats 71
r 825
TPS .44
IAC 23
cc 01
MAL 23
Hope this helps and if anyone thinks something is off or too high...I'm all ears cause I'm still tuning this car with the LT1 maf and Translator (regular).
I couldn't get that to work either. So I disconnect the batter for about 15 minutes, hooked everything up all at once, then started it up...ran fine.
On, On, On, Off
with both circular knobs as 1, 0 inside the translator.
Now, back to try tuning it some more...maybe chip this time.
837
AF 08
L8 56
Bat 14.1
Int 128
BL 128
MPH 00
CLT 165
r 850
TPS .48
cc 247
MAL 23
863
AF 07
L8 50
Bat 14.0
Int 128
BL 115
MPH 00
Clt 170
Ats 71
r 825
TPS .44
IAC 23
cc 01
MAL 23
On, On, On, Off
