Installed XFI back in January and got the idle and basic parameters set up with Cal. Since then I have replaced the Walbro 255 fuel pump with an Aeromotive 340. I ran a bigger return line and have the fuel pressure set, at idle, the same as it was with the 255. I have driven it around a bit to let the XFI learn and everything seems to be ok. The only thing I noticed is that when I originally set up the idle with Cal. The O2 correction at idle was about 2%. Now at warm idle it is 5.5%. Seems to be idling smoothly though. Is this anything I should give attention to or do I need to change something else after the fuel pump change. Thanks.
