Or take a piece of pipe with an ID close to but bigger than the OD of the bushing, cut the length to fit snugly inside the control arm, and the cut it lengthwise and place the two pieces around the bushing.
HRPartsNStuff makes a very trick bushing remover/installer. Works great on the uppers and lowers, including the ones in the ears on the differential housing.
Good luck,
Sumner (Buzz) White in Houston, TX (sumnerw@flash.net)
