I was at the junk yard and found a T-bird SC with the red top injectors. If I am not mistaken they are 30lb. What does a stock 85 T Riviera come with? Will they make a difference? What else would I need to upgrade? Also what PSI fuel pump should I be using? I will probably have to use and aftermarket rail mounted one. Would 50PSI be enough? Thanks
