I'm getting ready to do a stock to mild rebuild on an low mileage 84GN engine for my Regal. I'll be keeping the stock bore/stroke, heads, and intake. I have a turbo from an 87GN and it looks a little larger than the 84 turbo, I'd like to use that one. Is all I have to do is "clock it". I'm looking for some ideas/input on how to rebuild this motor on a budget (I'm a college student), but give it a little more $hit in its britches at the same time. Cam? Exhaust? Air intake? I'm new to the turbo buick world, I jumped aboard from the Mopar and Corvette crowd. Thanks in advance.
Donnie,
Welcome. :biggrin:
A few pointers from lots of reading and experiences;
1- List your goals and stick to them!
2 - NEVER FORGET; There is no such thing as a budget rebuild, since your build and goals will always exceed the budget!
3 - DO NOT rebuild the engine as a std SBC build. It will fail! (do a search on this)
4 - Spend part of the current budget on tuning tools (Recording type scantool and WB set-up). This will help to get the car running GOOD first, without KR. You will be MUCH further ahead than just adding performance "parts".
5 - The 87 turbo "may" seem attractive for now, but it will leak if not retrofitted with the correct seals for a Hot Air car. Some had good luck, but you are rolling the dice.
6 - As frustrating as it can get, don't forget to "Have fun"!
Edit;
Some of the experts here who have not been mentioned, come to mind, started this Hot Air thing and put the numbers down are;
Duane, Lee Thompson, Turbo6x2, and many others (forgot quite a few). Read, read, read.
