I'll try to keep this short.Spun a rod bearing,went with major rebuild.Upon inspection discovered block was already .030 over.found unbored 109 block ..020,eagle crank,k-1 rods,JE pistons,210-210 comp cams hyd roller,ported iron heads matched to intake,alky kit,50 msds,340 walbro,afpr,ta-49,thdp,2& 1/2 ATR,no cat.Still first 100 miles or so.Going to dyno tune in a couple months.With stock plenum and TB,{I know] i'm hoping to be over 400 rwhp.Conservative or realistic??still learning.Thanks dudes!almost forgot,car sees 23-24 pounds,no knock.alky about 3/4
