Let's try this in a new post. I did a search and didn't find my specific problem. I'm having rear-end noise issues that have gotten progressively worse, significantly so after a couple of hard launches. The noise is at its worst around 35 MPH with the foot lightly on the accelerator. Noise quits when lifting off the pedal. I had the rear-end checked with the fluid changed (posi-fluid was added) about a year ago. Does problem described sound like the ring and pinion? Does anyone know of a link describing how to remove the rear-end, as I believe I could remove it myself with instructions and take it to someone qualified to rebuild. Thank you for any help provided.
