My father's Monte SS is out just like my GN. Funny thing is I pulled the body off my GN this summer and there is not enough movement in the bushings to bring it back. We also did a body off on a friend's 67 GTO and it was out the same amount. I have had 3 78 Malibu's over the years and they were out the same way. I never heard of GM replacing rear ends for that reason and I used to deal with manufacturer claims and service bulletins. It also doesnt make sense because the axle shafts on all the G bodies are the same length from left to right. If one tube was longer than the other, then you would need 2 different length axle shafts. The only way I can see correcting it is trying to pull the rear over via adjustable upper control arms which I think is cheesy, using a wheel spacer on one side, having a new rear made with one tube longer than another option. Me personally, I am just going to leave mine the way it is.
