Do it Double D
The tweaks were very minor.
Jeremy, keep in mind that the pictures show the end links after I cut them down. Prior to that I had about 2 5/16" of threads showing when screwed all the way in.
I have a set of moogs on the back not sure of the p/n or ride height.
To use your term I am at 4" center to center.
I agree, sending long ends allows each install to be custom matched to ride height, and it doesn't take much effort to cut them down.
Good stuff.
Mike
Yeah I can tell your pics show the post-cut threads. They must have defintaley sent the wrong link with that much thread showing!
I have their initial bar that they sent out for vendors to test with so mine was already mounted once prior on a lowered Monte so I'm hoping mine should just bolt right up once i get my 9" in. I should also have a little more rear angle becuase of the diameter of my axle tubes so I might not have to use a spacer on the straps. Unfortunately I still have quite a bit of work to do on my rear housing before I can send it to get powder coated so I wont be mounting mine for a while!
