I installed both the KB type as pictured above and the "X" braces. The dual "XX" brace made of conduit will be far stronger than a single "X" stretching across the entire width of the car given that they are made from the same type of conduit. If doing a single "X" as mentioned earlier, you'll need to use much heavier tubing, something thicker than electrical conduit as its too weak to span that far of a distance across the entire width of the car.
