I was able to successfully install the Rear Feed Brake Line with the help of a fellow board member.
Replaced the hose that goes from that line to the rear axle while I was at it. So far so good.
I'm working with pre bent SS lines from Classic Tubes (I brought the complete Brake kit) and every line I replaced (all 4 wheel lines) had to fight to get the fittings threaded in. Now the rear feed line won't thread into the proportioning valve. Is there some trick?
The old fitting goes back in fine so the threads in the valve are okay.
Also in getting the old line out I snapped a bolt for the trans cross-member. The bushings are shot anyway but the point is can I drive/move the car with one side of the cross-member unbolted.
I ask cause I may need to have the car towed to the shop about a 1/2 mile from my house and let them deal with getting the line into the prop valve and then drive it home.
I feel so dejected after doing all that hard work getting the line in which the shop wouldn't do if I paid them just to get my ass whooped by a cheesy fitting.
Thanks.
Thanks.
