REAR END, TRANNY, DOORS
GullsGN
OLD HIPPIE
87GN Rear end 3oo.oo - Pending Sold - Thanks, Jake
87GN Transmission (with TC)300.00
87GN Doors (with mirrors and door handles, and window motors) 75.00 each Pending - Sold- Thanks, Josh
87GN Drive Shaft 50.00
87GN unused exhaust pipe. This is the pipe from the cat. a little surface rust. Tags still on it 50.00
87GN Hood no rust or dents. Needs paint. 200.00
Local pick up only. Charlton, MA
The Rear end is a 8.5 10 bolt posi with 3.42 gears? Drum to drum? Condition?
1st in line
The rear end was working when it was pulled. I simply cut the shocks and pulled. Drum to drum but I do not know the condition of the drums. I do believe it is a posi unit.
I'll take the rear as long as its a 8.5 10 bolt. Did it come out of a real GN? RPO will say G80. Can you take a few pics of the pumpkin or even better, pull dif cover and measure the ring gear. You can send pics to j.eberling@yahoo.com
I'm in NY and have no problem driving to come and pick it up. Thanks
The rpo g80 is for limited slip. Not 8.5/3.42. If it had an lc2 it's a 10.5 unless it's been swapped
I can come by on Friday afternoon to take a look at the doors, or maybe on Saturday?
-Mark
