Has anyone tried installing a rear disc brake setup on GN? I was told that a setup from any 93-97 Trans or Camaro is suppose to be a direct bolt on but according to the gentleman at my local brake/exh shop it ain't quite that easy. He said something to the effect of my original drum backing plates being welded on and the disc brake backing plate is a bolt on. I figure if that is true then perhaps the drum backing plate can be cut but I wanted some insight before taking the cutter to my rearend.
