This was not after brake boosting, it was after street driving for about 7 miles. But I will post in tranny and see if anyone has any feedback. Thanks guys
A TE-44 will suck off the line if the exhaust housing is not a Garrett like the stock turbo you replaced, and still have a stock torque converter.
Another thing to consider is not all D-5 stock converters are the same, as GM Parts had many different OEM suppliers and back in the early days I have seen them vary up to 400 RPM in original GN's.
I cannot believe Dusty did not ask you at what RPM do you see O PSI boost?
Heres my take... check the wastegate puck size. Then check to make sure you dont have a wastegate hole that has been produced for an external gate.
Had a Garret .63 housing on my TE44 and it was produced for external gate. My puck didnt contact the housing but went inside the hole.
My 44 spools faster and better than my stocker. 2800 12" pats converter.
Dont give up.... i love my 44
I can attest that 2200 is not enough on a 44 with the Precision .63 housing. The garret would be ok but he stated his stall is only 2100. I had 2200 with my D5 on me 44 and it still wasn't enough for a good launch.
