ok fellas, i need some infos. i know people on this board are running this set up or have ran this set-up. this is just for me to have a base of where i should have the settings.
first i would like to say that razors kit is the best, no knock at all even at 23 lbs of boost pump gas 93! at half throttle ran out of room. scared the crap out of me.
ok here it is, i'm running the trans + and extreme extender 23/21 98 oct with 83lbs inj, 70 gtq, 3800 stall, precision front mount. can any body share me your settings at the track with your boost and where you have adjusted the chip?
i understand that every car is different, but give me a safe setting.
boost?
fuel press?
blm?
wot tcc?
low gear fuel?
spool fuel?
the alky kit is on standard kick on at 4 to 5 psi.
thanks in advance
boost?
fuel press?
blm?
wot tcc?
low gear fuel?
spool fuel?
thanks in advance
