2 weeks ago I successfully installed Razor's alky kit on my GN. After install I took it out and tested it and all was fine.I turned up the boost to 23lbs, the alky to 6, and installed my turbo tweak chip alky chip. After some 1/8 mile street runs I was reading zero retard on the scanmaster and all was fine. I was seeing the green light at 4lbs boost like I'm supposed to and it obviously was spraying.
I took the car out today and immediately I knew something was wrong. I had retard from practically the first time i stepped on the gas (extremely light acceleration). When I got on a strightaway I slowly built up boost and at 4lbs the alky light came on red (it was never green). I backed off and stayed out of boost until I reached my destination (about 30mi). Once there I turned the car off turned the key to the ACC position and hit the test button. The Power injection light and the red light came on. When I got back on the road the problem was still there. It seems like the kit is not spraying.
The only things I did since I initially installed the alky and tested it was perform a a top-engine clean using Seafoam (following the directions on GNTTYPE) and switch out some vacuum lines (as Razor suggested in a thread I read). He suggested teeing the boost gauge off the vacuum line going to the canister and running a line straight from the last vacuum port to the 3 bar map. I did as suggested running the existing hard vacuum line to MAP and moving the boost gauge tee to the other side. I have not driven the car since the initial test.
I don't think any of this should have caused this problem, but I this point I don't know.
Where should I start troubleshooting?
