Can you set the alcky to come on under no boost? Because if you leaned that motor out and jumped the timing up four to six degrees you would tell a difference. You would have to have some sort of tuning device though. I bet with alcohol and proper tuning you could gain 20hp or so.
not trying to take a sale away from Razor or anything but i think on a stock Ls1 there are many other parts i would consider that will see some big gains with out much hassle.
agreed....get an air lid or if its an auto get a stall. For the same money you could get a used dry n20 kit. Once you go turbo or s/c ...get the alky kit!!!
The exception to this would be if the motor ran way higher compression like 13:1.. and nitrous.. and on top of that wanted additional timing on pump gas.. this is in the near future.. not yet :redface:
On a stock LS1... there is practically no benefit using alky injection.
