G glenn c New Member Joined Jun 1, 2001 Aug 30, 2003 #1 The rad. cooling fan on my wife's 86 T-type is staying on too long ...unplugged the delay relay but still stays on, it will turn off if i unplug the small relay. Could it be the temp sensor?
R REDS HOT AIR Buick Tweaker Joined May 24, 2001 Aug 30, 2003 #2 relays probly sticking next time tap on the relay and see if it cuts off you can switch plugs between the 2 relays and see if it still does it ..if so you know to replace the one thata sticking mine has done it from time to time when I get out the car ...a lil tap and cuts rght off
