racing Valve Covers, Shocks, RJC pulleys & much more
Sam Colalillo
low 9's w/ a 109
$49.00 (SOLD) Competition Engineering C2720 Adjustable Drag Shock
· 3 way adjustable drag shacks
· Less than 2,000 miles on them
· This is a pair of Rear shocks
$20.00 (SOLD) CATALYTIC CONVERTER TEST PIPE & 4-BOLT FLANGE
· replacement pipe to eliminate the catalytic converter for off road use only
· 4 bolt flange
· Never installed
$30.00 RJC racing boost controller
· http://rjcracing.com/product/boost-controller/
· Has less than 2,000 miles on it
$25.00 (SOLD) RCJ racing Rocker shaft supports
· Brand new never installed
· http://rjcracing.com/product/rocker-shaft-supports/
$95.00 (SOLD pending payment) RJC racing Race crank pulley
· 5 lbs lighter than the stock crank pulley
· 6061-T6 aluminum
· This is not an underdrive pulley
$54.00 (SOLD pending payment) RJC racing Billet water pump pulley
· This is the same diameter as the stock pulley
· 6061-T6 aluminum
$65.00 (SOLD pending payment) Belt Tensioner in good condition with RJC idler pulley
· Tensioner has under 40,00 miles on it
· Pulley is one year old
$80.00 Stock aluminum alternator, air conditioning & power steering mounting bracket
· Has under 40,000 miles on it and is in great condition
$150.00 (SOLD) Turbo Buick valve covers
· Black wrinkle coated
· -12 AN fittings welded to each valve cover (for hoese which route to the a vent tank)
$45.00 (SOLD) Coolant reservoir & windshield washer fluid tank Carbon fiber dipped
· These are stock parts which experienced the carbon fiber dip process
$45.00 Heater hose assembly
· Has an aftermarket heater control valve
· In good condition, no leaks, needs cleaned up
· Has under 40,00 miles on it
2nd on the tensioner if available!
Would you sell that alky control cap separately? How much for the shocks and that shipped?
Thanks,
John V
Not trying to jump in front of anyone, Im sure he will keep things in line. Ill take the shocks, rocker supports, both tanks and test pipe. PM me a invoice with PP addy
Thanks,
John V
im not going to separate the cap but i'll keep you informed who buys the tanks and maybe they will sell it to you.
pm me your zip code if your still interested in just the shocks and i'll give you a shipping price on the shocks.
You are next in line for the tanks and the and the test pipe. PM your zip code and ill get you a shipping price.
the rocker supports are sold and I'm waiting to hear from Launau Limited on shocks, you are next if he doesn't take them. I'll get you qoute on shipping those too.
