The 4 Seasons compressor is excellent, as I have used few of them on Gn's. It is the only new compressor being made in the USA, and it comes with a 2 year warranty.
There are a couple of issues you should know about when converting a GN to 134a.
First, cooling ability is reduced 20%, but that may not be an issue unless temps get over 100 deg.
Second, 134a will probably leak unless you have new type hoses that have a barrier liner.
Also, be careful with the replacement dryer, as the made in China ones I have used all leak at the hose fitting connections.
