turbojimmy
Supporting Member
- May 26, 2001
Hi all,
The past few years I've been whining about hitting a performance 'wall' at around 114-115 MPH. This year I've added a T70 turbo and headers hoping maybe to get beyond 115 MPH. The car 'feels' stronger - at least throttle response is better. I headed out to the track last night and got essentially the same timeslips I've been getting for about 4 years now. High 11s at around 113-114 MPH. I'm not running a lot of boost - around 23 PSI - and I know I need to crank it up in order to go faster (and to make best use of the T70) but I think some of my numbers show that I'm pretty close to peaked out so I'm looking for opinions (and have some other questions). I have the mods to get me into the 10s so I guess it's a matter of tuning?
First, my (narrowband) O2s start at 850 and get down to 805 at the end of the run. Seems to me that this is pretty good - maybe a little fat. EGTs are high-1500s, low-1600s. Given this it doesn't it seem like I don't really have room for another 4-5 PSI? I'm running 27/25 timing and C116 fuel. I can probably get away with 29/27 or 29 flat out.
Second, how much range should I be able to get out of a HD actuator? Last night I was trying to get more boost out of the T70 and just couldn't. I'm using an HD actuator and a simple bleeder for boost control. It seems my range is like 3 or 4 PSI. I've got the rod pretty tight and only saw about 23-24 PSI with the bleeder wide open. If I close the bleeder completely I have like 20 PSI.
Third (more of a curiousity), what does the MAT reading have to do with anything? Since I made my MAF 'blow-thru' I now have the air filter (and thus MAT sensor) under the hood rather than behind the bumper. MAT temps were 100+ on a high-30 degree ambient temp night. I'm used to seeing MAT temps that reflect ambient temps but I don't know if it really matters.
Fourth, the good news is that I'm picking up more MPH between the 1/8th and 1/4 than I ever have. I'm getting like 22-24 MPH from the 1/8th to the end of the 1/4 - used to get 20-21. But I'm way down in the 1/8th. I've gone from a best of 96 MPH in the 1/8th to 89-90 MPH. I put a new Vigilante converter in the car last year that I thought might be slowing me down but looking at the RPM and shift points it's almost identical to my old 9x11 (except that it actually locks under WOT). It keeps the engine operating in the 4900-5500 RPM range the length of the track. Is this too tight? How does one measure converter efficiency (I've seen the term but I don't know how to calculate it)?
Fifth, and related to the converter question above, my chip locks the converter at 90 MPH. Would I gain anything by locking it earlier? Looking at the RPM and MPH plot you can barely see where it locks which makes me think I may benefit from locking it earlier? I don't want to bog it down, but if I'm locking it at a point where it's already coupled pretty good what good does it do?
I guess that's it - sorry for the long post. I think it was a decent first run of the season. Even though it was Friday the 13th I did have a bit of good luck in that I didn't set my car on fire. I drained the 93 out of the tank and added the C116 and forgot to hook the fuel pressure gauge back up to the rail. Closed the hood, cranked it over. Nothing. Cranked some more nothing. Smelled gas. Popped the hood and there was C116 EVERYWHERE. I let it air out for about 15 mins and ran it. Unfortunately EVERYTHING still smells like fuel: the interior, under the hood, me, the garage, etc. Hopefully it will air out. On the positive side C116 makes an excellent (albeit expensive) degreaser.
Jim
Jim
