I have a question for you guys running solid MAF pipes. I’m thinking about getting one for my car so I can remove the stock plastic elbow and silicone accordion tube, but I have a concern about vibration. With a solid MAF pipe, what takes up engine vibration and movement and prevents the MAF and filter from being bounced around and beat up? Right now, engine vibration and movement is isolated in the silicone accordion pipe, and none of it gets to the MAF and filter. I’m worried that with a solid pipe engine torque movement and vibration will cause my MAF and filter to vibrate and rub on the washer fluid tank and vapor canister. Can you cut the MAF pipe a few inches back and splice in a section of the factory silicone accordion hose to take up the movement? Or is there another way?
I’d appreciate any pictures of engine compartments with solid MAF pipes, especially close-ups of the MAF/airfilter area so I can see how things fit.
Also, is there any better way to hold down the MAF and filter? Right now my MAF/filter is resting on the upper radiator hose, washer fluid tank, and the vapor canister. It’s not held down in any way, it’s just sitting there. There’s a 9” K&N cone on the end BTW. I know there has to be a better way to do this, so I’d like to hear what you guys are doing and get pictures if possible.
Also, what brand solid MAF pipes are you running? I hear action fabrication made the best, but they’re now out of business. ATR still makes them… how are they? Is there a better brand? Or should I just stick with the stock setup and check it for leaks every now and then?
Also, I’ve seen some pics of cars with heavy duty blue intercooler hoses. Where can I get these? The blue would match my plug wires.
Thanks!
Thanks!
