On the 3 pads that bolt to the flexplate, does in matter if the pads are not machined flat surface? I picked up a converter and 2 pads are not a clean flat surface. I know the previous own had a bolt come out and a 2nd come loose. It sounded like a rod knock but was loose bolts. Anyway the pads are scuffed up and not flat. Would that cause problems? I was thinking it could cause some vibrations. Could the vibrations cause engine damage like spun bearings?
Thanks for any help.
Chuck
Chuck
