I had to change the motor on my stock brake system and I was wondering if I had to bleed my brakes? If so do I just bleed them the same way I would if I had changed my brakes? Thanks Nic.
No, you just have to cycle your accumulator.
Turn on the key to Pump up, press the pedal about 10 times to pump down.
Don't let the new motor run more than 20 seconds.
Don't allow the ps bowl to run dry or overfill it.
