1980 Buick
- Aug 17, 2009
HELP:
I have (still) NO Turbo function ... NOTHING. I have a free spinning Turbo, a correctly functioning waste-gate actuator, and functioning pressure oper. dash lights or "Turbo Power" lites * (they work when you put shop pressure into the hose (under the hood at comp. base) *appx. 7-12 lbs to get yellow / red lights to come on the dash ).
So, in trying to diagnose this, I now have the Down Pipe off, I can see the Turbo "turbine" (looking at me), *** (again it spins freely, NO Play)*** So then I start the car, and at just above an idle, the compressor (turbine) turns. THEN: "Rev it" and it screams ! (the Turbine) I cannot stand the smell / noise and I am afraid to drive it this way as it may ruin the cars hood. I did find a couple of kinks in the "down-pipe" (right off the Turbo down to cat. converter) *this pipes 3-4 feet long and I took it too a local muffler place to see if another one can be created (made). I suppose I should try to see what if ANY pressure I'm building up (on a gauge) ?
But has anyone seen / observed a supposedly "good" Turbo that won't work EVER ???
Anyone have any other ideas ? Theirs NO Vacuum hose to the waste-gate (it's plugged off) ... just the pressure hose off the compressor base "that's it" The PEVR valve is out, (but that's academic at this point as I understand it ???) "I'd just like a "basic Turbo function" but again, it's DEAD.
I poised this question before and still can't seem to figure it out. ALL THIS IS 100% Factory OEM. (this car.)
< Any suggestions appr. >
