BLACKHAWK38
- May 26, 2002
What is the stock length for push rods ?
I will be putting on a re-worked 8445 IRONS with Manley 1.77" intake valve on a Junk yard 1986 2 barrel 109, do not know if the block will be decked down or not,
Not a High HP rebuild, .030 Trw pistons, arp main studs, arp rod bolts on stock rods, double roller timing chain, new front cover, reed 188/188 236H grind flat tappet .403 lift cam( Granny cam) CROYLOGENTIC treated along valve springs to match.
new GM lifters, TA performance hardened rocker shafts, sealed power R869 and R870 stamped steel rocker arms, stock valve covers, .010 rods and Mains FEDERAL MOGUL bearings, New Front cover and oil pump cover and gears, Camshaft bumper bearing
BALANCED CRANK, fLEXPLATE AND FRONT DAMPER ,ect
IT is fun spending money when putting together a new engine,
REGARDS, Blackhawk38
