I'm pondering just adding pure oxygen injection. Get a O2 cylinder, some high pressure line, a solenoid, and a jet. O2 should be MUCH cheaper than N20, considering it's used alot in gas welding. I have been trying to figure out why anyone uses N20 when there is O2. O2 obviously is pure oxygen, where N20 is 1/3 oxygen. So, you would only have to use 1/3 as much to get the same HP shot. All regular air is is 79% N2, and 21% O2, so I fail to see how using N20 or 02 makes any difference in the final composistion of the air in the combustion chamber, just that you need to use O2 at a much lower total rate. Consider air is 21% oxygen, N20 is 36% oxygen. That's about a 70% higher concentration of oxygen. In theory, if your car was sucking up PURE N20, it should be capable of making 70% more power than air. Now, to compare, 02 is well, 100%. Using a spreadsheet I compared the final oxygen concentration, using a % for air, N20, and O2. I show O2 as being 526% as effective as N20 at increasing final oxygen concentration. So, you need to use only about 1/5th as much O2 as you would N20 to get the same HP boost. Considering it's probably less to refill a O2 cylinder at a welding store than a N20 bottle at the race store, it sounds like it could be MUCH cheaper in the long run, and each bottle will go 5x as far. Unless I'm totally missing something.
So why is N20 so popular, and nobody uses O2? Is is the fact that O2 is reactive at the moment of injection, but N20 doesn't break apart into N2 and O until 576C (combustion begins)? Does the extra oxygen make pre ignition happen faster/easier? That may be it, but I wonder if the use of water/methanol injection would counteract that anyway.
SNIP
Ah....I discovered something. O2 is stored as a highly compressed gas, at about 2000psi. N20 is compressed until it's a liquid, so a lot more mass of N20 can fit in a bottle than O2. Best I can figure, about 5x mass of N20 fits in a cylinder as O2. So in the end, a tank will last about the same for the same HP shot. Darn.
SNIP
