Hey all. I came to this forum because I've been around the Turbo Buick community since 96 and figured on there being some good knowledge here.
A friend has a late model GM pickup with the gas V8 and runs it on propane sometimes.
In the event of a propane backfire, the ~90 degree elbow from the TB to the propane injection block gets blown up. At 50$ a pop.
Is there anything technically wrong with fabbing an elbow (of aluminum) and installing a blowoff valve set low since the truck is naturally aspirated?
Between that and rebuilding a trans., my Sunday may be busy.
Thanks for any technical input. In case this is a good plan and someone in Phx. area might have a source on an affordable and effective blowoff valve, speak up.
-Matthew
-Matthew
