does anyone know of a tachometer mount or braket that will allow you to mount the tach. on the instrument cluster (top right side, either above the corner or off to the side) without drilling any visible holes?
what I have in mind would install behind the instrument cluster and extend out above/around the right side of the cluster and give you a steady place to mount a tach. maybe fabricated from aluminum?
the idea is to mount a tach. in a good location for visibility and still be able to remove everything and return the interior to stock appearance if you want to later (no holes in the cluster housing).
If I had more time, I'd attempt to fab one up myself. But then again, if I had more time, there's a lot of things I'd do to my Buick.
Thanks,
Rob
Thanks,
Rob
