Coelacanth
- Jul 7, 2014
I'm replacing my stock injectors with 60# units. I didn't even get my first nut removed before running into a problem. I got the fuel rail return line disconnected and went to unscrew the lock-nut holding down the rear-most vacuum line, but the nut is bit into the bracket really good and I'm at risk of kinking the rear-most line. As I start twisting counter-clockwise, the line and line bracket both twist along with it. How the eff do you remove that lock-nut without damaging that vacuum line?
And while I'm at it, what is the trick to pulling off the rubber lines at the vacuum block?
