grandnati0nal
- Sep 28, 2004
Ok i have some definate problems with my car but i am not worried since i am rebuilding the motor this winter. Anyways if you care to guess what the problem is go ahead. Here are the symptoms:
1. 14.9 @ 87.58mph 2.088 60' This is the biggest symptom.
2. very rough idle.
3. studder when going from an idle.
4. 205 temps for the coolant.
5. did i mention a VERY rough idle.
Scanmaster readings are normal says a friend that has a GN. All of the sensors like the TPS and IAC are in order. I think it is a wiped lobe or two on the cam. I am open to any ideas on this. The heads and intake will be pulled this weekend and maybe the cam because i want to see if that is the problem. Lets hear some of your conclutions.
2. very rough idle.
