I installed a Accufab 70mm tb, plenum and 1" spacer. PROBLEM: Without adjusting the TV cable the car shifted much differently. 1-2 shift seems similar to before. The 2-3 is more drawn out. At 60 mph I have to let off on the gas to hit overdrive. I adjusted the TV cable as per instructions on GNTTYPE.ORG and now the car is shifting way too early in all gears. At very light throttle it shifts 1-2-3 at 25 mph and goes into overdrive at about 40 mph. I had previously marked the position of the TV cable so I moved it back towards the firewall where it was before. Now for my QUESTION: Did installing the Accufab tb, plenum and spacer somehow change the geometry of the throttle/TV linkage or what? It's fine to manually set the TV but as soon as I go WOT it pulls the cable out too far. any suggestions please respond.
TIA Bill
TIA Bill
