There isn't much to know. All they did was add an adjustment screw to the preload spring inside the regulator. It still works the same way as a stock regulator...fuel pressure increases 1 psi for every 1 psi of boost. It just adds adjustability to the base pressure most likely in the 35-60psi range. It's hard to say who made yours since most of them look the same.
