Precision Turbo's Remanufactured turbo sale.
RUQWKNF
KEEPER OF SECRETS
Staff member
Our turbo wizards in the turbo room, have recently remanufactured a whole list of turbos and some of them are Buick specific. We have decided to pass along these units to the Turbo Buick community first, to give everyone on the board first dibs. All of these units have been fully remanufactured and completely serviced with new bearings, seals and thrust bearings. We have also decided to offer these units a unbeatable prices as well. So get them while they are hot everyone.
1. TE-44 with polished compressor cover.
TE-44 turbocharger with polished E compressor cover, Garrett 3-bolt .63 A/R turbine housing, The wastegate hole has been ported to 1.328”, so this housing would be best suited to a downpipe with an external wastegate mounted directly to the downpipe. This is a journal bearing unit with our standard 360* thrust bearing. It features a cast 58mm compressor wheel with a T-31 stage 3 turbine wheel. This turbocharger can support up to 565 flywheel hp when maxed out and needs a 2600-3000 stall converter for the best possible spoolup. This turbocharger is best suited for a bolt on combination looking to run low 12’s to mid 11’s in the quarter mile. Sale price $450.00 plus freight.
2. TA-63 with stock appearing compressor cover.
TA-63 stock appearing turbocharger with a Garrett .82 A/R Buick 3-bolt turbine housing. The wastegate hole has been ported to 1.037” so it should work with all internal and external wastegated downpipes. This is a journal bearing unit with our standard 360* thrust bearing. It can support up to 675 flywheel hp when maxed out and needs a 3300 – 3500 stall converter for the best possible spoolup. It features a 63mm cast compressor wheel with a P-trim turbine wheel. This turbocharger is best suited for a built combination that includes head work, intake and cam. It would perform best on a combination looking to run low 11’s to mid 10’s in the quarter mile and maintain a true stock appearing look. No inlet bell included with this turbo, but a stock or aftermarket inlet bell will bolt right up. Sale price $600.00 plus freight.
3. T64E turbocharger with an E compressor cover.
T64E turbocharger with an E compressor cover, Precision .85 A/R Buick 3-bolt turbine housing. The wastegate hole looks to be the as cast size as it measures .931". so this housing should work with all internal and external wastegated downpipes. This is a journal bearing unit with our standard 360* thrust bearing. This turbocharger can support up to 690 flywheel hp when maxed out and needs a 3300-3500 stall converter for the best possible spoolup. It features a 66mm cast compressor wheel with a P-trim turbine wheel. This turbocharger is best suited for a built combination that includes head work, intake and cam. It would perform best on a combination looking to run high 10’s to 10.40’s in the quarter mile. Sale price $500.00 plus freight.
4. PT70-1 turbocharger with a HP ported shroud compressor cover.
PT70-1 turbocharger with an HP compressor cover, Precision .63 A/R Buick 3-bolt turbine housing. The wastegate hole has been ported to 1.264" and would work best with an external wastegate mounted directly to the downpipe. This is a journal bearing unit with our standard 360* thrust bearing. This turbocharger can support 820 flywheel hp when maxed out and needs a 3200-3400 stall converter for the best possible spoolup. It features a 70mm cast compressor wheel with a P-trim turbine wheel. This turbocharger is best suited for a built combination that includes head work, intake and cam. It would perform best on a combination looking to run mid 10’s to 10 flat in the quarter mile. Sale price $500.00 plus freight.
These units are sold without a wastegate actuator or warranty. Wastegate actuators are sold separately for these units. If you are interested in one of these units, or if you have any questions about them, please give us a call here at the office. Monday through Friday 8 am - 6 pm CST. # 219-996-7832
And as always, thank you for your continued support. We appreciate your business.
Patrick
Territory 2 Accounts Manager / Sales Rep
Precision Turbo
Precision Turbo and Engine: Turbochargers, Air/Fuel Delivery, Boost Control, Racing
how much shipped for one of the te44 to 55075 ?
let me know and i can pay.
thanks
PHANTASM,
I got your PM, I'll be in touch shortly with the freight quote.
Thanks for your patience.
Patrick
bigwill,
I will get with our shipping department for your freight quote and be back in touch with you asap.
Everyone, please call us with any inquiries or questions you may have about these Reman units.
219-996-7832
My work load prohibits me from monitoring this post 24/7.
Thanks.
Patrick
PHANTASM and bigwill,
I sent you both PMs for your respective freight quotes.
Please call us at 219-996-7832 if you would like to purchase.
All 4 turbos listed above, are sitting on the shelf looking for new homes.
:D
Patrick
Update
TE44 turbo sold to PHANTASM.
Thanks Steve.
PT70-1 sale pending, awaiting payment.
Thanks guys.
Patrick
Update # 2
PT70-1 turbo sold to bigwill.
Thanks again William.
Patrick
Update #3
Turbo #3 T64E turbo sold to Joe.
Thanks again Joe.
t-typex1
Yes, the ones pictured means there's only one.
Still have turbo #2 left, that is the TA-63, but more to come.
So stay tuned everyone.
Patrick
ROUND 2 !!!!! Ding Ding!!!!
Turbo #2 is still up for grabs.TA-63
5. PT6176 turbocharger with an E compressor cover
PT6176 turbocharger with an E compressor cover, Precision .63 A/R Buick 3-bolt turbine housing. It features a 61mm compressor wheel with a P-trim turbine wheel. The wastegate hole looks to be the as cast size, so it would need to be port matched to whatever style downpipe you are using. This is a journal bearing unit with our standard 360* thrust bearing. This turbocharger can support 680 flywheel hp when maxed out and needs a 3200-3400 stall converter for the best possible spoolup. This turbocharger is best suited for a built combination that includes head work, intake and cam. It would perform best on a combination looking to run low 11's to high 10’s in the quarter mile.
Sales price $500.00 plus freight.
6. PT71GTQ turbocharger with an H compressor cover.
PT71GTQ turbocharger with an H compressor cover, Precision .85 A/R Buick 3-bolt turbine housing. The wastegate hole has been ported to 1.292” so this housing would be best suited to a downpipe with an external wastegate mounted directly to the downpipe. This is a journal bearing unit with our standard 360* thrust bearing. This turbocharger can support up to 880 flywheel hp when maxed out and needs a 3600-4000 stall converter if you intend to run it on a 235ci motor. On a 240 – 250 ci motor, the stall requirements would be less. This unit features our first generation 71mm billet compressor wheel with a GTQ turbine wheel. This turbocharger is best suited for a full race built combination that includes bottom end, heads, intake and cam. This turbo was the first 71mm turbo that was deemed legal for TSM class competition. (Turbo Street Modified)
It would perform best on a combination looking to run high to mid 9’s in the quarter mile. Sale price $800.00 plus freight.
7. TE-44 turbocharger with E compressor cover.
TE-44 turbocharger with E compressor cover, Precision .63 A/R Buick 3-bolt turbine housing. The wastegate hole has been ported to 1.040” so it should work with all internal and external wastegated downpipes. This is a journal bearing unit with our standard 360* thrust bearing. This turbocharger can support up to 565 flywheel hp when maxed out and needs a 2600-3000 stall converter for the best possible spoolup. This turbocharger is best suited for a bolt on combination looking to run low 12’s to mid 11’s in the quarter mile. Sale price $450.00 plus freight.
8. PT70-1 turbocharger with an HP compressor cover.
PT70-1 turbocharger with an HP compressor cover, Precision .85 A/R Buick 3-bolt turbine housing. The wastegate hole has been ported to 1.284” so it is best suited for use with an external wastegate mounted on the downpipe. This is a journal bearing unit with our standard 360* thrust bearing. This turbocharger can support 820 flywheel hp when maxed out and needs a 3200-3400 stall converter for the best possible spoolup. This turbocharger is best suited for a built combination that includes head work, intake and cam. It would perform best on a combination looking to run mid 10’s to 10 flat in the quarter mile. Sale price $500.00 plus freight.This one is identical to the other PT70-1 that we sold earlier, except that is has a Precision .85 A/R housing.
These units are sold without a wastegate actuator or warranty, just like the first batch. Wastegate actuators are sold separately for these units. If you are interested in one of these units, or if you have any questions about them, please give us a call here at the office. Monday through Friday 8 am - 6 pm CST. # 219-996-7832
Patrick
Update #4
PT6176E sold first thing this morning.
Thanks Louis.
Patrick
Update #5
PT70-1 turbo #8 sold to John.
Thanks John.
Patrick
Great deals here. Leaves a lot of room to get a good converter to really wake up most of the cars on here based on the sigs i read. Any of these will run bottom 10's with the exception of the 44's.
