Precision 74 GTQ
Firechaser
V8-2 cylinders=2x the $
74 GTQ, .85 housing, 3 bolt, H cover (4in/3 out). Turbo works fine, I wanted a quicker spool for the street so I went smaller. I used the car for street only at 22lbs, no shaft play...worked perfect. It has powdercoated cover & exhaust housing, does have some small scratches in the cover as seen in the picture...I got it that way. $725...NOW $575 shipped to the lower 48, paypal ok.
I also have a very nice chrome cover that fits this turbo if anyone is interested.
Nobody wants a big Precision?? $725 I'll include the pretty turbo shroud, let's go guys...someone needs a big Turbo! Offers??
$700 w/ the turbo cover...here's a pic, 'tis shiny and fits over this turbo
I'm having a hard time find a compressor map for this turbo.... do you know where I could find one? this may work for my setup, so I'm interested
this is all i can find, i remember reading it's good for 900 hp, the Turbo makes big power...that i can say and it's in very good shape (no shaft play). I only used it at 22 lbs on the street and that was very little.
Inducer 74mm
Wheel Inducer: 2.942"
Wheel Exducer: 4.030"
Wheel Trim 53mm
4" Inlet/ 3" Discharge
360 deg thrust
I don't know...I never tracked this car, doesn't have a cage and I couldn't go past 22 lbs or the car was uncontrollable :)
