Driver side crank case ventilation . Disconnect the hose between the air filter and the turbo (2 hoses) from the ccv, and hold on to something when you look into this contraption. unbolt the 2 small bolts that connect it to the bracket. Cut the band off of the hose on the bottom of the contraption your are about to chunk but leave it attached to the valve cover assm. Get a section of 4" exhaust pipe or intake pipe to take the place of the contraption. Get a double male 3/4" hose connector with clamps and about 4or 5 ft. of 3/4" heater hose. Turn the 90 degree section of hose left on the valve cover assm toward the drvr side fender and connect your heater hose and run it to the bottomside of the truck. You will notice better throttle response. You might as well flush your intercooler it will probably have a lot of oily residue in it. Dont put a valve cover breather in the filler neck. Gets grime on every thing. TyrodOriginally posted by UnderdogGN
I have a 2000 crew cab F350. I love the diablo tuner. I have not done any testing but seat of the pants is like night and day. The truck feels like it dropped about 2500 lbs. I have not had the opportunity to use the diagnostic portion yet. We used the diagnostic portion of the superchip to pull codes from my brothers truck and it worked fine. I am actually 1bad85gn. I think my nephew must have logged on to my computer.
I also have not changed the bypass? I just started modding my truck about 2 weeks ago. FIPK and tuner only so far. I just ordered a 4 inch turbo back stainless exhaust. Can you tell me more about the bypass?
that's a duraslackOriginally posted by buickboy
Buy a Duramax!
RJ, A friend of mine has a 92 2wd and is wanting to bump the 160hp up to 200. THe non-wastegate blower isnt helping in the matter. Know anyone that could shed some light here? I have noticed numerous areas to bellmouth in the intake track. Just curious if there is some hidden power to unleash like on the powerstrokes.Originally posted by Race Jace
I have a 92 dodge cumings. 350k so far with no tranny problems. no engine problems. I have changed the fan clutch, radiator and a few u joints. it has 33" tires and pulls my car around allot. i never have to go below 70mph pulling my car no matter how big the hill and there are some pretty big hills here in the rockies. the thing is just awesome!
my only complaint is it rides rough with the solid axle compared to the newer chevys fords and dodges.
I wish dodge had a bigger rear seat like the fords. that would be nice.
