Powermaster ?'s
stss96
I have s-10 wheel cylinders and soft shoes and my car still can't hold any boost on the line. My powermaster motor turns on everytime i touch the brakes. I am guessing its not holding enough pressure. I replaced the accumalator and it does the same thing. Where to look next?
When you say it comes on every time, is that when you mash the pedal down or just when you push moderately. I can believe it if the pedal is mashed. If it does it when the pedal is pushed for a normal stop then its probably the pressure switch.
If its only when mashed and you hold it, does the pump shut off again or keep running?
It happens when you push on the brake moderately, I am going to try the pressure switch I just need to find a wrench thats big enough.
