Powermaster/Hydroboosts brake rod removal
channer
Hi
Has anyone removed the brake rod from a Powermaster or Hydroboosts brake system. If yes, how?
thanks... dave
Yep rod end to the booster. I dont have a clue what that tool is used for. Maybe a newer truck. Maybe a 2 ton truck?
Hi turbofish38
I have an extra HB I've been playing around with... Where is the snap ring? For the life of me... I still can't figure out how take that brake rod out:confused:
dave
Hi turbofish38
dave
I am converting P/M to the Hydra-boost. Do need that Gold Mounting Plate or Can use the one of the P/M I am coverting a 1987 to 1984 Hydra-boost.
Any help would Grate as I have been purchasing Reman Parts from the Parts
Store I don't have Doner Car for Parts
Hi Jeff
I can sell you the 14karat gold mounting plate if you want:biggrin:
If you get yourself a GN 84/85 hydraboost system, it should come with it's own mounting braket and should bolt right in. No mod needed for the firewall... I can't be 100% positive about the brake pedal but it should work with the 86/87 TR cars.
dave
