I thought I had all of my powermaster problems behind me for a while. Until I was driving home and I applied the brake and that %&*%# brake light came on and the pedal got soft. Well, I nursed it home and while sitting in the drive way the light went off. I shut the car off and turned the key forward and I could hear the pump run for a few seconds and stop. “It was work correctly” However when I keep pushing the pedal on and off the brake pedal would go down and get softer and the brake light would come on then the pump would run turning off the light. I would also get my brake pressure back. Fluid levels are ok and no leaks to be found. Has anyone seen this before? Accumulator ball? Any suggestions would be appreciated! Thanks
