transducer
I purchased the transducer from AlkyControl. Per Julio, it is a 150 psi transducer. Not sure of the voltage range, however i believe i am tapping into a 5 volt source at the throttle body location. I can check tonight as well as get into the power loger files. it is pretty accurate at idle however it is low at WOT. Julio is pretty sure (and I agree) the error is in the calibration tables in the Powerlogger being 100 psi vs. the 150 psi transducer. Will update this evening.
