T t3intercooled Member Joined Jul 20, 2004 Apr 1, 2008 #1 I am wiring up the powerlogger, which wire on a stock harness for the 3 bar map sensor is the sender wire? Thanks in advance for the responses
J Jbenn911 Still tryin to learn !! Joined Jan 11, 2004 Apr 2, 2008 #2 t3intercooled said: I am wiring up the powerlogger, which wire on a stock harness for the 3 bar map sensor is the sender wire? Thanks in advance for the responses Click to expand... Green one... you can also tap under the dash for the signal.. I took mine off the stock boost guage, since it was dead anyway
